Consuming BIM for Indoor Maps
927
01-08-2024 09:17 PM
jauhari_mani
Greetings Community,
I'm currently working on incorporating BIM data indoors, and I've successfully accomplished the following tasks:
1. Established an Indoor Database.
2. Created an Indoor 3D Dataset.
3. Imported BIM data into the Indoor Dataset.
However, when I attempt to utilize the "Generate Indoor Pathways" tools for preliminary pathways, I encounter an error. I've attached the logs for your reference.
I'm seeking insights into potential missing information in the BIM file that could be causing this issue. Any assistance would be appreciated.
Messages
Start Time: 08 January 2024 13:31:21
Generating pathways for 1 facility and a total of 3 unique levels…
Beginning pathway generation for facility 123…
Generating pathways using a calculated lattice rotation of 90…
Refining lattice for level 123.01_-_Entry_Level…
ERROR 180068: Unable to create the level pathways.
ERROR 160706: Cannot acquire a lock.
Failed to execute (Near).
Failed script Generate Indoor Pathways...
Failed to execute (GenerateIndoorPathways).
Failed at 08 January 2024 13:32:07 (Elapsed Time: 46.13 seconds)
AnninaHirschiWyss
Did you try to close and reopen the project before running the tool again?
Close the project, check the .gdb folder for .lock files and delete them?
HTH,
Annina
AnninaHirschiWyss
HTH,
Annina
