Change Units Name in ArcGIS Indoor Hosted Map
786
11-30-2023 04:15 AM
jauhari_mani
I've developed an indoor map hosted on ArcGIS Online and intend to integrate it into my webpage using the WebMap Class in the ArcGIS JS SDK. I aim to grant specific users the ability to update unit names, which should then be reflected for all application users.
I'd appreciate insights on potential solutions to achieve this.
Best regards,
Mani Jauhari
JasonHineEsri
Hi Mani!
The SDK provides a sample showing how to enable attribute value editing in a Popup. See if it gives you some ideas for the functionality you describe!
JasonHineEsri
Hi Mani!
GauravJobanputra
Hello @jauhari_mani I'm hoping @JasonHineEsri's response worked for you. If yes, then pls Accept as Solution to help other community members. Thanks.
