Hello Community, I am stack in creating stereo pairs after doing Block adjustment tool to create digital surface model. I have run the block adjustment tool but when I run the Build stereo tool it runs then gives empty results. It says "No built stereo views, Change parameters" How can I change parameters! I am dealing with a small area but when I try to define angles that can be seen reasonable, it returns always empty and same message. How Can I change!After You run Build stereo model, You build 3d point cloud and create the digital surface model after. @VinayViswambharan Can you tell about? I need to create the DSM from here
