I can't configure the server and service provider in Image Server Manager,
1772
04-08-2011 02:08 PM
GongjingCao
Hello, there,
I was trying to configure the server and service provider in Image Server Manager by clicking "File"->"add server"(like here: http://webhelp.esri.com/arcgisserver/9.3/Java/index.htm#register_image_server.htm), but there is no response after I clicked it. That configuration window never showed up.
Does anybody know why? Is there something I missed? How can I make it work?
Thanks!
MarceloBorsoi
If the Windows is Vista or 7, you can try execute the ArcGIS Image Server Manager as administrator.
Start > All Program > ArcGIS > Image Server
right button in Server Manager
execute as administrator
JeffreySwain
If you are using Win 2008, then please log a support incident as there are specific instructions regarding permissions that need to be granted.  Win 2008 is preventing access to a particular folder.  Otherwise be sure that you are logged in under administrative account.
GongjingCao
Marcelo and Jeff, Thanks for you replies.
It is running on Windows Server 2008. From Jeff's reply, seems a permission needs to be granted to me. Which folder should be set the permission?
Thanks!
