hi all, I want to display a set of integer rasters (1 band, 32 bit) in an image service using a color map. So I added them to a mosaic dataset (also 1 band, 32 bit) and then applied my colormap file to that mosaic dataset using the Colormap function. The colors display properly in ArcCatalog when I preview the mosaic dataset.
But then I generated an image service from the mosaic dataset and I just see gray in the preview of the image service. Anybody know what the problem is and what I need to do to make this work?
Thanks!
Dan
