ArcIMS consuming Image Service?
1155
05-25-2010 06:41 AM
GlennGoodrich
Is it possible to get ArcIMS 9.2 to consume an ArcGIS Image Service?  I have tried adding the service to an mxd and then publishing it via ArcMap Server, but I get a "No valid layers found" error in the ArcMap Server logs
Can this be done?  Do we have the technology?
Glenn
GlennGoodrich
BTW, we've done everything here and it still doesn't like it.
GlennGoodrich
So, we got this to work by also installing the ArcGIS Image Server ArcGIS 9.2 Client on the ArcIMS Server.  That was not listed in the above post.
ArcIMS
ArcEngine install on the ArcGIS Image Server DVD
ArcGIS Image Server Client Core
ArcGIS Image Server ArcGIS 9.2 Client (this likely preempts the Client Core)
Hope this helps anyone else unfortunate enough to still be using ArcIMS.
