Arc GIS add on for Bentley products
3130
12-20-2010 10:29 AM
DavidMcMillan1
We were using Microstation XM and were using the Arc image server add on from ESRI.  Is their one available for Microstation V8i?
MelanieHarlow
The ArcGIS Image Server client for MicroStation is compatible with MicroStation 8.05 and 8.09 (V8 XM). It has not been modified to work with V8i (V 8.11).
RichardDaniels
MVP Regular Contributor
Is MicrosStation v8i supported yet? I'm looking for the new MicroStation Client for Image Server.
RichardDaniels
From ESRI Support
Unfortunately, ArcGIS Image Server MicroStation client V8 XM, http://resources.arcgis.com/gallery/file/image-management/details?entryID=5C1D61A4-1422-2418-8827-39..., is the last one developed. There are no newer clients being developed for MicroStation (or other software).
MicroStation v8i does support Web Mapping Services (WMS), so if you publish your imagery via ArcGIS Server as a WMS service you can now add it into v8i.
Rich
