Hello,
I'm trying to use the following model:
Land Cover Classification (Aerial Imagery) - Overview (arcgis.com)
And following this guide to "fine-tune" a pretrained model: Fine-Tune a Pretrained Deep Learning Model (esri.com)
The "ModelName" in the .emd file is "UnetClassifier". I don't have this option to export training data into this format from "Export Training Data for Deep Learning (Image Analyst)" Is there a way to create a training file from ArcGIS pro?
I was able to complete this process here: (2) Solved: Re: Can't Re-Train ESRI Model - Esri Community
@rescobar here are detailed steps - https://doc.arcgis.com/en/pretrained-models/latest/imagery/finetuning-the-land-cover-classification-aerial-imagery-.htm
You should be looking for the Classified Tile metadata format in the Export Training Data for Deep Learning (Image Analyst)"In the Train Deep Learning tool tool - you don't have to set UNET either.
I try to use the "Export Training Data For Deep Learning (Image Analyst)" but I get this: 002088: Feature class does not contain enough information for supervised training.—ArcGIS Pro | Documentation
I do have "ClassName" and ClassValue fields in the feature class I'm trying to use.
Try to assign the {Class Value Field} Parameter in Export Training Data Tool to the name of the field which has these values which is in your data {ClassValue}
If I use a shapefile as the "Input Feature Class Or Classfied Raster or Table". The {Class Value Field} doesn't populate - I have a "ClassValue" field in the shapefile. If I use the output of a previous operation to test this function, it tells me the raster is not thematic (Error 002090 Raster is not thematic.)
Signed in members can post, follow updates, and more. New here? Register a free account.
