Possible to use new training data for Land Cover Classification model?
2104
04-24-2024 01:29 PM
rescobar
Hello,
I'm trying to use the following model:
Land Cover Classification (Aerial Imagery) - Overview (arcgis.com)
And following this guide to "fine-tune" a pretrained model: Fine-Tune a Pretrained Deep Learning Model (esri.com)
The "ModelName" in the .emd file is "UnetClassifier". I don't have this option to export training data into this format from "Export Training Data for Deep Learning (Image Analyst)" Is there a way to create a training file from ArcGIS pro?
rescobar
PavanYadav
@rescobar here are detailed steps - https://doc.arcgis.com/en/pretrained-models/latest/imagery/finetuning-the-land-cover-classification-...
You should be looking for  the Classified Tile metadata format in the Export Training Data for Deep Learning (Image Analyst)"
In the Train Deep Learning tool tool - you don't have to set UNET either.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
rescobar
I try to use the "Export Training Data For Deep Learning (Image Analyst)" but I get this: 002088: Feature class does not contain enough information for supervised training.—ArcGIS Pro | Docu...
I do have "ClassName" and ClassValue fields in the feature class I'm trying to use.Error_exporting.PNG
Muhammad_Elbagoury
Try to assign the {Class Value Field} Parameter in Export Training Data Tool to the name of the field which has these values which is in your data {ClassValue}
rescobar
If I use a shapefile as the "Input Feature Class Or Classfied Raster or Table". The {Class Value Field} doesn't populate - I have a "ClassValue" field in the shapefile. If I use the output of a previous operation to test this function, it tells me the raster is not thematic (Error 002090 Raster is not thematic.)
rescobar
I was able to complete this process here: (2) Solved: Re: Can't Re-Train ESRI Model - Esri Community
