Label Objects for Deep Learning Class Value Bug
1143
12-15-2025 11:33 AM
JoshBerna
I'm encountering what I believe can only be deemed a bug with the deep learning tool "label objects for deep learning."
In summary, changing the class value of a training sample in the manager does not actually change its class value.
I prepared a feature layer of training samples in hopes of automating parking lot digitization on our campus. This feature layer is composed of 4 different types of features, or "classes," blacktop, sidewalk, curbs, and marking lines.
The schema is simple. It's the 4 classes, blacktop, curbs, sidewalks, marking lines, with values of 1, 2, 3, and 4, respectively.
So, I import the feature layer, then assign each sample to match its respective class identified in the schema. This appears to work, but it does not actually, and this is where the bug comes in. Though it appears as though its been updated in the training samples manager, it doesn't actually update the internal class value for a training sample.
For example, lets say I'm updating a sidewalk feature because it imported as class_497 automatically. I update it to sidewalk, class value 3, and it appears as though it worked. I save the training samples and close Pro for the day. The next day, I come back in and reopen the tool. I import my data that I'd saved the previous day and that sidewalk sample is class_497 again, not my sidewalk class I specified yesterday. The value never actually updates internally. So, while the training samples manager can make it appear as though the class value is actually updated when fixing up your samples, its not.
I've attached a video of the workflow so you can see exactly what I mean. Updates made to the training samples are purely cosmetic, as the underlying data does not change.
Please let me know if I'm missing something! So far, the only way I can get a sample with the proper class value is by making a new feature within the sample manager itself.
ShivaniPathak
Hi @JoshBerna are you still facing this issue?
JoshBerna
Hi Shivani,
I was able to get around this issue by creating a classvalue and classname field in the feature layer before importing it as training samples. This seemed to make the tool happy. I do still see the specific behavior mentioned in my original post however.
Though now I am not sure if this is an issue with the training sample creation tool or just the way it handles saving training features. It's possible that the classes, when manually assigned in the tool, do retain those class values upon exporting the training samples. It may simply be an issue with the "save as" button of the tool. Perhaps, when the features are exported as training samples, rather than saved as a training data feature layer, they do retain their class values.
I'd have to test this by training a model, which I don't have time for today, but I can do soon.
In any case, I do still see the behavior where using the "save as" button doesn't retain the feature's assigned class values from the tool.
PavanYadav
Hi @JoshBerna
your expectations are correct for both scenarios:
  1. If labeling is in progress and you use the Export Training Data tool within the pane, it should include all current work in the exported chips/labels.
  2. Once you have saved your labels using the 'Save' or 'Save As' options, all work—including features and labels—should be preserved. In this case, you would use the Export Training Data (Geoprocessing) tool.
If you experience any data loss in either scenario, please let us know.
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
