zoom to item's extent
2450
7
07-06-2018 10:20 AM
DaveOrlando
can someone explain why selecting any particular item (either from the list or the extent box on the map) zooms the map to the world extent?...
I've read some posts blaming other features that have bad extents but that makes no sense. The extent box is already on the map and highlights ever so nicely when hovering over the item, yet it doesn't / can't / won't use that geometry....
I should note that I have other sites (same vintage) that work fine and I've explored the features of both sites and can't see any differences. If anything, the site that works has one feature with a bad extent, yet it works.
by Anonymous User
Not applicable
It's something to do with the default extent configuration for sites. If you try creating a new site without changing the default extent in the site configuration, it should operate as expected. Either way it's definitely a bug on our end.
by Anonymous User
Not applicable
Can you provide a link to a site with the behavior you describe? I am unable to reproduce on my end.
DaveOrlando
by Anonymous User
Not applicable
Thanks for providing those examples and for alerting us to the issue. I was able to reproduce and we are working on getting a fix out soon.
DaveOrlando
Thanks for looking into it.
I've been Googling other Open Data sites to see if I'm not alone and there are others that are behaving the same.
by Anonymous User
Not applicable
DaveOrlando
Patrick Hammons wrote:
....... Either way it's definitely a bug on our end.
seems to be fixed, thank-you
by Anonymous User
Not applicable
Happy to hear it's fixed!
