What is the best way to change the format of the datasets search results?
1042
03-16-2017 01:23 PM
KenDoman
When you perform a dataset or a tag search, what is the best way to change the format of the search results? They accept the color selections from the main application. But what if you want the images for search results on the left instead of on the right, or make the dataset titles centered instead of aligning left. Is there a way to create a custom template with the components positioned the way you want them to be, like there is with other parts of the Open Data site?
