Hi, I'm having a small issue with our hub site where the search box's text and background are both white. I haven't made any changes to the theme nor do I have custom CSS so I'm not sure how this began. Similar issue with the top navigation search box. Where in the hub site settings do I fix this?
The search card is currently pulling colors from the Header Text Color and the Header Background Color. Try adjusting those and then follow @ABishop 's comment.
@Alex-Santos
Under your hub "Theme" settings, try adjusting the "Button Background Color" or the "Body Background Color". Sometimes these settings change depending on changes or upgrades done by ESRI to this solution.
Hey thanks. I thought those might be it too. I changed them around but still finding the same issue. I checked row settings too.
Since the search bar falls within the global navigation, you'll want to adjust the Global Nav Text Color setting under Customize > Theme.
I set the global nav text color to black and global background to white. This resolved the global navigation. The search card still has the same issue.
Try saving, publishing, exiting, then clearing your browser cache. Sometimes this helps in updating settings.
Signed in members can post, follow updates, and more. New here? Register a free account.
