Link to a named anchor
3736
11
03-09-2017 05:21 PM
BruceGodfrey
I'm doing some testing with 2.0.  Is there a way to link to a named anchor from the header?  For example, when initially creating the default site you see text in the header like: <li><a href="#about">About</a></li>.
Is there a way to link down the page to a row or text card?
I'm not having any luck trying markdown or html approaches.
-Bruce
CourtneyClaessens
Hi Bruce,
We had this working with markdown before - we'll look into it.
Courtney
KevinDunlop
I am also having the same issue.
CourtneyClaessens
Bruce, Kevin -
This bug is fixed and will be released Tuesday, 3/21.
Courtney
KevinDunlop
Thanks Courtney for the fast replay.  You guys rock!
BruceGodfrey
Thank you Courtney.  It is working for me now.  -Bruce
KevinDunlop
Hi Courtney,
Is there a way you can change the way Open Data handles anchors?  The problem we are encountering is that the title bar (one with your login info to the right) covers up the first part of where the anchor jumps to.  So if I put my anchor on the title of the section I want to jump to, the title is covered up the bar.  We ended up putting the anchors at the end of the previous sections as a workaround, but that can lead to problems later if we add new sections.
Thanks
JohnWolf2
Hi Kevin,
Were you ever able to resolve this?  I'm running into the exact same problem.
John Wolf
BobBistrais
Is there a way to use standard HTML code for the named anchors, such as <a name="data">My Data</a>
-instead of Markdown?  I want to use anchors with other HTML tags and it doesn't seem to work when using Markdown format.
CourtneyClaessens
Hi Bob,
There's no way to do this right now, though we can add it to our backlog.
Courtney
