I want to remove the percentage and only show value in the label and also the tooltip. Also is it possible to concatenate text with field where I can add "$" in front of the value?
"type": "pie",
"datasets": [
"url": "URL",
"query": {
"where": "FOCUS_AREA='parksrec' AND UNIQUE_ID='1'",
"orderByFields": "Source",
"groupByFieldsForStatistics": "Source",
"outStatistics": [
"statisticType": "sum",
"onStatisticField": "Amount",
"outStatisticFieldName": "Amount"
"series": [
"category": {
"field": "Source",
"label": "Source"
"value": {
"field": "Amount",
"label": "Funding"
"style": {
"padding": {
"top": 5,
"bottom": 5
"pie": {
"expand": -50
"legend": {
"visible": true
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
