Is there a "Community Ideas Wall" capability in ARCGIS Hub Initiatives?
1437
5
08-04-2021 05:29 AM
Vikram
Hello All,
Is there a Idea wall kind a functionality in HUB?, where the community could mention their ideas as a post it or some other way and all the ideas are visible to the community and the community members are given a functionlity to like and support any idea posted...
KaraUtter
@Vikram I thought there may have been an option under the community initiatives licensing, but if there isn't you can always create and embed a survey123 for the comments and next to it embed a single-panel operations dashboard list with the comments showing?
Vikram
Hello @KaraUtter , was looking for some options which is similar to https://www.socialpinpoint.com/product-ideaswall/. Survey123 is good for capturing data. However it can be presented as postits or tiles, it would be a helpful one...
KaraUtter
@Vikram thank you for the link - that's a really neat product! Hope you can find something that will work for you.
Alex-Santos
Hey there. Check out Escondido's volunteer hub and the "submit an idea" section. I forget the template they're using for this web app. But it has the 'like' functionality you're thinking of. https://volunteer.escondido.org/pages/ideas. Of course, this relies on a spatial workflow and not sure if you can hide the map or do this without a map. If spatial is needed then perhaps you could have users place points on their zip code. An idea for an idea...
Vikram
Hello Alex, It is a very good example what you specified. will explore more on how this can be utilized without using the map. We were checking to find if something similar to https://www.socialpinpoint.com/product-ideaswall/ would be possible on ARCGIS HUB or any other Arcgis feature...Thanks again for the lead...
