Is it possible to see the code of the header ?
811
02-13-2020 08:05 AM
DarioPeña_Mena
Hi Im making a site in Hub, and I found one page  that I like too much, and I want to use the code of the header, obviously I will change a lot of things I just want to use the schema.
Does anyone know how can I see the code of the header?.
The page that I found was also made in Hub.
Tags (1)
MelissaBrooks
Check this out, towards the end I recall her talking about how to access the code of live hub sites, hopefully it shows you what you need, other than contacting them directly?
https://www.youtube.com/watch?v=MZG180zQ2Es&t=908s
Melissa Brooks
Senior Geospatial Systems Specialist
Tasman District Council (New Zealand)
by Anonymous User
Not applicable
This is no longer possible...I would suggest you inspect the HTML if you are curious how someone did something or contact them as Melissa points out above.
