Hub Application Item Open in New Tab
1664
06-29-2022 11:51 AM
KansasDASC
We have a number of applications that are discoverable in our Hub site. There is one item that has a symbol next to it in the search results that when clicked, opens the application in a new tab, outside of Hub.
Then there's other applications that don't have this symbol and when clicked, opens the application as a Hub item showing the application, but surrounded by the Hub application.
How do I add or remove this symbol/ability, so that all applications open external to the Hub, or remove it so that all applications can open inside of the Hub?
versus...
KlaraSchmitt
@KansasDASC ,
In your site editor, go to Settings > Interactions and enable the Embedded Apps toggle. This will keep applications opening under your site header and the links in search results should not display the "opens external link / new tab" symbol.
KansasDASC
Hi @KlaraSchmitt we already had the Embedded Apps toggled to on and as a test, I toggled it off, then back on, saved then draft, then published, and there was no change with the issue.
KlaraSchmitt
Hello @KansasDASC ,
Hmm. I'm not sure then. It seems like it could be a bug; unfortunately, I am not super knowledgable when it comes to issues in the search catalog. Have you tried reaching out to Support to see if they can assist?
KansasDASC
Not yet, I was hoping this was something that I overlooked in the settings at the AGOL item level or configuration within Hub.
