Hosting Images (Pictures) token expires on Portal
1294
07-07-2021 01:11 PM
MaryCadena1
Hello Community,
I uploaded pictures to the portal so that I can use them in Hub. Here are my broken files:
 From this source here it says to use the API to call to get the item data
I did this:
https://xxxxx.xxx.xxxx.xxx/portal/sharing/rest/content/items/3d1dfc900c3146898a6330e0c700580d/data
and it's not working. What am I missing?
I really appreciate any help you can provide.
Mary
BrianRollison
Hi @MaryCadena1 you can upload your images directly to the site by using the Image Card and/or Row Card (depending on your needs).  These images are stored on the site itself and respect the sharing configuration of the site.
We don't yet support selecting an existing "Image" in your organization in either card but have considered it on the long-term backlog.  If you'd like to open this up as a community idea in the ArcGIS Hub board we'll continue to monitor it there.
elpinguino
Hi @BrianRollison  has this capability been added into the Hub? I have to put images into cards and noticed the image isn't sticking. I loaded the images into AGOL because I thought that made sense since the Hub is an ArcGIS Online product. Is it still the case we need to host images outside of AGOL to put in the Hub?
