Hosted feature layer downloads in ArcGIS Hub do not contain metadata
231
02-23-2026 08:10 PM
Y_Maree
My organisation uses our ArcGIS Hub site to provide our data to the public. In the past few months, we’ve noticed some inconsistencies with whether metadata is attached to the files downloaded from our catalogue.
After some testing to try to rule out different variables, it seems like the downloads that are missing metadata are hosted feature layers where we added xml metadata using the portal metadata editor shown below.
Here is a summary of the behaviour we’ve noticed in our ArcGIS Hub:
Layer type
Publishing method
Metadata entry method
Download file from ArcGIS Hub
result
Share as web layer (copy) from ArcGIS Pro
Use metadata editor in ArcGIS Pro v3.5+
Shapefile / File geodatabase / SQLite
Metadata is preserved in the downloaded file including shapefile (xml component)
Use ArcGIS Enterprise 11.5 / ArcGIS Online metadata editor after the layer is published
No metadata in the downloaded file
Referenced feature layer
Add portal item from service URL
Shapefile
The xml component preserves the metadata we entered
We’ve noticed BUG-000148198 for ArcGIS Hub about metadata in downloaded shapefiles, but this issue seems broader than that because we aren’t seeing the metadata in the file geodatabase downloaded from ArcGIS Hub either. However, it seems like metadata is downloading for some types of layers where we’ve used the portal metadata editor to add it, just not the hosted feature layers.
Is this the expected behaviour for hosted feature layers downloaded from ArcGIS Hub?
