Harvesting ArcGIS Hub and geoserver support?
858
05-18-2022 09:44 AM
DuncanHornby
MVP Notable Contributor
All,
I have essentially two questions about using ArcGIS Hub:
  1. Can ArcGIS hub harvest another portal, e.g. the FAO geonetwork portal? Reading the ArcGIS Hub help file it appears that it can be harvested as discussed here but being novice to this subject I could not determine if Hub can harvest from another data portal? Unless I have missed something it seems that Hub can only be harvested, is this correct?
  2. If I wanted to set up an ArcGIS Hub site can the data sit on a geoserver server or does all data have to sit in ArcGIS Online? I ask this question as we have a limited number of credits and storing large dataset on ArcGIS Online uses a lot of credits. I wondered if we could store data on geoserver as a way of avoiding credit usage?
Duncan
