Disable Downloads on ArcGIS Hub
6535
15
02-28-2018 05:56 PM
JohnPlunkett
Hello
I have a public ArcGIS Hub
ArcGIS Hub
I have a hosted feature service on ArcGIS Online
http://spt-eaglegis.maps.arcgis.com/home/item.html?id=ec7899ee5f5b4c7394753476c08b08d1#overview
And the ability to export is disabled
When I open up in Open Data
ArcGIS Hub
The option to download is present. - is this thie right setting to disable downloads?
I have been testing with other sites and have seen conflicting results
DanielFenton1
Hi John and Sarah,
There is no way to do this directly and we do not have plans to add such an option at this time. As a workaround you could include the layer in a web map and share the web map on your site. That would allow display but not downloads.
Daniel Fenton
Software Engineer | ArcGIS Hub
RebeccaStrauch__GISP
Is it shared or in a group that is shared with OpenData/HUB?  Have you tried unsharing it?  This will also make it undiscoverable by OpenData/Hub from what I understand, but still should be available thru AGOL.
(If you still want it to show in OpenData/HUB, then I don't know.)
JohnPlunkett
Hi Rebecca,
Thanks for your response
Yes data is shared to a group with Open Data/Hub
If I unshare it from that group it will disapear from Open Data/Hub.
I want it to remain in Open Data/Hub but I want my users to see it but not export it.
*Edit - added Hub to get the right terminology.
SarahZaleski1
I have the same question.  Is there anyway to enable the data viewable on the map in HUB, but not downloadable.
Thanks!
DanielFenton1
Hi John and Sarah,
Daniel Fenton
JohnPlunkett
Daniel
Thank you for the response.
Have a good week
John
SarahZaleski1
Thanks
JoanBastide
Hi Daniel,
It is a pity that this is not even in the plan. It would be very useful for hub owners to have more flexibility on the sharing options.
Best regards
Joan
by Anonymous User
Not applicable
Hi Joan,
Can you say more about your use case? We support private data to limit downloads to authenticated users in your org as well as maps for displaying rather than sharing data. Is there a need we've missed?
Patrick
AmandaJobmann
Yes, I would like some authenticated users to view maps only, not download them. I need the maps locked down.
