Dataset view bug
1710
05-27-2021 05:09 AM
by Anonymous User
Not applicable
Advise needed. After launching new version of ArcGIS Hub, our custom header code is not working properly when viewing the redesigned content of datasets (see pic1) - icons "info", "filter", "download", "favourites" have some kind of transparency and I don´t know how to fix it in CSS. The similar mistake appears when clicking on "I want to use this" at the left lower corner (see pic2).
Does anyone have any ideas? Many many thanks
Martin (dvorak.martin@brno.cz)
Here is the css code:
.align-items-center {
display: flex;
align-items: center;
@media screen and (min-width: 769px) {
.navbar-wrapper {
display: flex !important;
.nav-wrap{
text-transform: uppercase;
.navbar-nav > li >a {
/*color: #da2128;*/
color: black;
font-weight: bold;
font-size: 14px;
.navbar-nav > li >ul>li>a {
color: black;
font-weight: bold;
.navbar-nav > li >a:hover{
color:#da2128;
background-color: transparent;
cursor: pointer;
.navbar-nav > li >ul>li>a:hover{
color:#da2128;
cursor: pointer;
.navbar-nav > li >ul>li>ul>li>a:hover{
color:#da2128;
cursor: pointer;
.navbar-nav > li >ul>li>ul>li>a{
color: black;
font-weight: bold;
.navbar-header{
text-align:right;
.navbar-toggle {
float: none;
/*margin-right:25px;*/
.dropdown-menu{
background: rgba(255,255,255,0.9) !important;
text-align: left;
.submenu{
left:100%;
top:0px;
.nav .open>a, .nav .open>a:focus, .nav .open>a:hover, .nav .open>a:visited {
background-color: #f2f2f2;
border-color: #f2f2f2;
opacity: 0.5;
.navbar-nav > .active > a:focus {
background-color: #ffffff;
opacity: 1.0;
.navbar-default {
display: none;
@media screen and (max-width: 1025px) {
.navbar-default {
display: block;
.dropdown:hover .dropdown-menu {
display: block;
margin-top: 0;
#main-menu{
float:right!important
@media screen and (max-width: 768px) {
.navbar {
min-height: auto;
.navbar-toggle {
margin: 0;
padding: 0;
.navbar-toggle h4 {
margin-top: 0;
.first-tier {
height: 50px;
.first-tier .row {
margin: 5px 0;
.navbar-nav>li>a {
padding-top: 10px;
padding-bottom: 10px;
line-height: 20px;
ul.nav.navbar-nav {
display: block;
position:relative;
ul.dropdown-menu{
display: block;
border-style:none;
.submenu{
left:0%;
top:auto;
.navbar-collapse .dropdown-menu {
position: static;
top: auto;
left: auto;
display: none;
float: none;
max-width: none;
padding: 0;
margin: 0 15px;
border: none;
-webkit-border-radius: 0;
-moz-border-radius: 0;
border-radius: 0;
-webkit-box-shadow: none;
-moz-box-shadow: none;
box-shadow: none;
.navbar-collapse .open > .dropdown-menu {
display: block;
.dropdown-menu .submenu {
display: block;
.navbar-collapse .dropdown-menu:before,
.navbar-collapse .dropdown-menu:after {
display: none;
.navbar-collapse .nav > li > .dropdown-menu:before,
.navbar-collapse .nav > li > .dropdown-menu:after {
display: none;
@media (min-width: 1200px){
.container {
width: 1200px !important;
padding-left: 0;
padding-right: 0;
/* HUB TOOLBAR */
#hub-toolbar, .side-panel-tab-controls {
background: #DA2128 !important;
#hub-toolbar .active, .side-panel-tab-controls .active {
background: white !important;
#hub-toolbar .active svg, .side-panel-tab-controls .active svg {
fill: #DA2128 !important;
#hub-toolbar .stacked-icon svg, .side-panel-tab-controls svg {
fill: white !important;
KlaraSchmitt
@Anonymous User
I'm sorry that is happening. I believe what you are seeing is that you have `transparent` set as your Body Background Color in the site theme. You'd want to change that to something solid, maybe white `#ffffff` because we use that variable in many places. You can learn more in my post about how theming gets applied.
KlaraSchmitt
@Anonymous User
by Anonymous User
Not applicable
Dear Klara, thanks a lot for a quick response. It wasn´t necessary to change it on css code, but only in the general theme setup (body background color was set to transparent, so I changed it according your advice). Many thanks
