Create rasters at same row and column
1331
09-09-2019 11:03 AM
BruceMiller1
I need to update ASCII files with new data for spatial distributions mapping of critters.
I have created the new reclassified rasters from my poly layers but can not seem to be able to get ASCII grids to match the same column and row size although the cell size does seem to be retained.
I have tried virtually every tool I have in  ArcMap 10.8 or ArcPro to no avail.
There used to be a way to do this using an existing "Mask" or bounding poly for the area of interest and all would be the same number of rows and columns with the same coordinate reference.
However, for some reason, I also can not get the R based Geospatial Modeling Environment to now run on old machine to do the clip rasters.  I need to Clip global climate data to match the area I am working then need to project the results as UTM zone 16.  Seems the Project Raster also is not working in ArcMap 10.8 or ArcPro.
Tags (1)
BruceMiller1
Anybody out there?
