API Error Open Data Download
38341
47
06-09-2021 11:01 AM
Tony_J_Van_Der_Wielen
We started seeing and API error in the download section of our Open Data page. It looks like there are no reported issues on Esri's end https://status.arcgis.com/.
Has anyone seen this? Or do you know how to fix it? This is happening with all our content.
Thank you!
Tony
Tags (1)
ThomasHervey1
Esri Alum
Hello again,
I apologize for the inconvenience. We have identified the issue and we're aiming to release a hotfix as soon as possible. Thank you for suggesting a work-around @John_Spence .
For future reference, ArcGIS Hub has a service-level status page found at  https://hubstatus.arcgis.com/
ThomasHervey1
Esri Alum
I want to give an update on the status of this fix.
We have found a solution but we need time to ensure that automated and manual testing is comprehensive and that no other gallery cards or header links regress. As a result, we will not be able to release the fix today, but we are aiming to release as soon as possible.
When a fix has been released and verified on production, we will update hubstatus.arcgis.com
ThomasHervey1
Esri Alum
Hello
We have just released a follow-up fix. Please check to see if you're still seeing an API Error on your downloads when navigating to content via a header link or a gallery card.
JosephBisig
We started noticing this on three of our recently published feature services. This is what we see on our Historic Election Precincts 2004.
We are seeing these API errors occur in two other feature classes as well -
https://gisdata-piercecowa.opendata.arcgis.com/datasets/pierce-county-council-districts/explore
https://gisdata-piercecowa.opendata.arcgis.com/datasets/historic-election-precincts-1992/explore
Has this issue popped up again for anyone else?
Joey
ThomasHervey1
Esri Alum
Hi @JosephBisig
We understand that the "API Error" is generic and can be confusing. Have you enabled the "Local Projections" setting on the Hub site? Hub needs a numeric SRID and will throw an error when trying to query metadata without one. For example, on this item on Hub https://gisdata-piercecowa.opendata.arcgis.com/datasets/pierce-county-council-districts/explore the Hub API returns an error when trying to get metadata. On that item's service
the Spatial Reference is
      PROJCS["NAD_1983_HARN_StatePlane_Washington_South_FIPS_4602_Feet",GEOGCS["GCS_North_American_1983_HARN",DATUM["D_North_American_1983_HARN",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1640416.666666667],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-120.5],PARAMETER["Standard_Parallel_1",45.83333333333334],PARAMETER["Standard_Parallel_2",47.33333333333334],PARAMETER["Latitude_Of_Origin",45.33333333333334],UNIT["Foot_US",0.3048006096012192]],VERTCS["NAVD_1988",VDATUM["North_American_Vertical_Datum_1988"],PARAMETER["Vertical_Shift",0.0],PARAMETER["Direction",1.0],UNIT["Foot_US",0.3048006096012192]]
I believe that you'll either need to make an adjustment to the service's spatial reference or disable local projections, which will serve results in EPSG 4326.
JosephBisig
Hi Thomas!
These items now work on our Hub site. It did look like a projection issue that was solved by reloading the data into our map projects and republishing. Always appreciate the help Thomas!
Joey
AnibalMmartinez
Hola, tengo el mismo error en ARCGIS ENTERPRISE 10.9. con un servicio FeatureAccess: Enabed y compartido como publico ¿Alguna idea?
Saludos,
Anibal
avonmoos
Can you provide a screenshot of where the local projections setting is? I can't locate it.
valenj88
From the looks of this, it seems like having standalone tables without spatial component aren't supported for hub download?
DianaKalil
I captured Web traffic with the URLs of the open data-Hub and it took me to: Resource was not found, and it was showing a 404 error.
Based on previous research I verified the item ID in ArcGIS Online and Spatial Reference, and it was 32145, so Spatial reference was not the issue.
I reviewed the REST services for other layers in the same and they worked for downloading. I suggested republishing the dataset since apparently there is no gap in the Spatial Reference or Metadata, and also verifying the export data settings.
