MXD with a large amount of layers crashes frequently when idle. This issue only happens on Windows 10 PCs and only with this one particular MXD. Any ideas for steps to take to troubleshoot this issue?
All of my troubleshooting efforts rebuilding several times repathing and moving lose layers to gdbs to limit the amount of locations is starting to point to a windows caching issues or a drop in network connection.
If there is no crash message, then it could be the project and where files are located... if they aren't the same, then a rebuild might be in order.
Also... if any of the files are not stored locally, then it might be a communications problem between the computer and the network. There is no one 'fix' that accounts for a project to crash and none have been associated with windows 10 that didn't have another root cause.
Exact same machines. I have tried stripping layers out to find the bad layers. I thought I had found them but after a few days the crashing started up again.
are the machines the exact same (memory, video etc) except for windows 10?
Quick fix... go to the machine that isn't failing and remove anything that isn't necessary
