A Gallery card in an ArcGIS Enterprise Site is a great way to display web maps available in ArcGIS Enterprise. Prior to 11.1, we could select a web map card from the Gallery and this would open in the Portal Map Viewer which was great. Unfortunately, it now takes us to the page below. We understand that this page can be useful for certain use cases, however, there should be a way to configure the Gallery card so that it supports 3 options for opening Maps:
- Default (as it works today)
- Map Viewer - rather than opening the page below, it should open the Map Viewer
- Editor - rather than opening the page below, it should open the new in 11.3 Editor
We are currently creating an item in Portal for ArcGIS for each map that points to the default map viewer URL and using the Apps gallery card to display it. This is done manually and is a bit annoying as we have lot's of web maps being created all the time.
Jose
