Hub can now display your saved layer style
2733
8
10-07-2025 10:03 AM
E-B_Davis
If you are a data editor or manager in ArcGIS Hub, a new capability allows you to display a layer's customized style so that viewers can more easily understand the data they're exploring.
Valuable time and resources go towards collecting, maintaining, and sharing data. Now you can share your authoritative data in a way that gives you more control over which data are displayed, which features or attributes are highlighted, and whether symbology is accessible to all. Custom styling is particularly relevant to larger or complex datasets, as another tool to fine tune what your data communicates.
Previously, layers in explore view were styled with Hub's default blue. With this enhancement, feature service editors can now choose between the default style or set the style of the layer from the item settings in ArcGIS Online.
Ready to try out this new option? Follow the steps below:
  1. From your dataset’s explore page, select the Manage content button to navigate to workspace.
    Manage content button on dataset explore page.Manage content button on dataset explore page.
  2. From here, select Settings > General.
    Workspace general settings.Workspace general settings.
  3. You’ll now see a Map display settings section that allows you to toggle between the Hub default style and the Saved layer style.
    Map display settings.Map display settings.
  4. Want to go ahead and update the layer style? Select the link to Edit layer styles in ArcGIS Online. This takes you to the item’s Visualization page in a new tab where you can update and save the symbology.
    Map display settings option to edit style in ArcGIS Online.Map display settings option to edit style in ArcGIS Online.
    Visualization tab in ArcGIS Online.Visualization tab in ArcGIS Online.
  5. Now, back in the workspace (General pane), when you select Saved layer map style, select Save, and return to the layer’s explore view in Hub, you’ll see the updated style.
    Saved layer style option in map settings.Saved layer style option in map settings.
    Updated layer style in explore page.Updated layer style in explore page.
And there you are – users now see your data the way you intended, giving them the ability to better understand the data they're exploring.
Dig into the Hub web help for details on editing and managing content items.
8 Comments
Martin1
Thank you. This is good news.
Is it already planned that this functionality will become accessible on ArcGIS Enterprise Sites?
E-B_Davis
Thanks so much for your comment, @Martin1. This functionality will not be a part of the Enterprise 12.0 release, but is planned for a future release.
Justin_Greco
@E-B_Davis does this only apply to point layers?  I tried with both lines and polygons, but its still the default blue symbol.  I did get it to work for a point layer though.  I was recently asked about this from one of our GIS users, glad to see its an option!
Update: I was able to get this to work for a line and a polygon layer.  To get it to work, I had to make a slight change to the symbology and then hit save on the visualization tab.  It wasn't just taking the existing symbology.
BrandonGuo
Why there's no settings for the whole site? If you have a hub with lots of data shared, admin needs to change those settings one by one?
AndrewRudin1
Glad to see some progress in this space for symbology.  Is this setting saved to the original item, or is it on some kind of Hub "twin" of the original item?  I'm thinking of situations where a layer is shared to to more than one hub's content library.
And how can I scan my item's json to find item that have this setting applied or not applied?
This is getting to @BrandonGuo 's comment.  I'd prefer to be able to set the original style option at the Site level, or at least be able to set it as the default at the site level.
I created a new Idea for this here:  Ability to set ArcGIS Hub layer symbology and styl... - Esri Community
So please go upvote it if you would find this useful.
CatrionaIllingworth_home
We would love to use these settings as we often get feedback from the users of our publicly available data that it would be much easier to understand with the proper symbology rather than the default blue symbology that the hub shows in the explore view.
However, we haven’t been able to utilise the saved layer style symbology, as nearly all our symbology isn’t set within our ArcGIS Online organization. Our team heavily utilises distributed collaboration and publishing from ArcGIS Pro for most of our publicly available data. Despite significant testing, we can’t get it to acknowledge these as saved layer styles, with it only recognising symbology that is set in the same ArcGIS online organization as our public hub. Going through and manually editing all the symbology in ArcGIS online is not a great solution for us as some of this symbology is hard to replicate in ArcGIS online and there would be so many services to edit that the time overhead would be huge.
Also agree the ability to do this for the whole ArcGIS Hub and not individual shared data would be amazing and save us so much time. There aren’t any datasets we would want to keep as the default symbology.
BrandonGuo
Hi @E-B_Davis Labels are not supported or there's a bug? I turned on display saved style, but labels are not showing up.
E-B_Davis
@BrandonGuo Thank you for your questions and comments. Labels are currently not supported, but that's a great idea, and an enhancement we will consider in the future.
Additionally, @AndrewRudin1, thank you for submitting that idea, and for your added context, @CatrionaIllingworth_home; these are use cases I will bring back to the team to discuss potential future enhancements.
