Why is the 'measured versus the predicted' so systematically distributed as in the figure below?
1073
03-08-2022 06:07 AM
Elijah
Elijah_0-1646748155801.pngThe image is a view of EBKRP cross validation  output.
EricKrause
@Elijah
Each horizontal line of points in the graph appears to have the same Measured value on the y-axis (or very close to equal).  However, they each have a different Predicted value on the x-axis.
Having many repeated values in the field you used to interpolate would produce this kind of graph.  This isn't necessarily a problem, but you should look into it and confirm that the repeated values are expected in your data.
EricKrause
@Elijah
