I'm using the kriging analysis tool in ArcMap (10.7.1) to be able to export the semivariogram graph values. For the analysis, I'm using ordinary kriging, Box-Cox transformation type with no trend, and the exponential mathematical model. I want to understand the equation behind this model and I'm confused about how to interpret the equation that appears below the semivariogram (attached below). Going through the documentation I found this web page: https://pro.arcgis.com/en/pro-app/latest/tool-reference/3d-analyst/how-kriging-works.htm . There I saw the equation that is used for the exponential model, but when calculating the y-axis values using the model equation I do not obtain the same results that I exported from ArcMap.
I want to know as I'm trying to graph the values obtained but with the distance in kilometers (which I can convert from degrees to km) but to get the y-axis values for the model I want to compute them using the model equation.
I will appreciate any insight or help.
