Which Feature Service REST URL to use for GeoEvent Server
173
10-04-2024 05:35 PM
TimHayes3
I want to add my GeoEvent Feature Service to Map Viewer Classic in AGOL. I need to know which URL is the right one to use:
https://mygis.mycity.gov/mymachine/rest/services/GeoEventMap/FeatureServer
or
https://mygis.mycity.gov/mymachine/rest/services/GeoEventMap/FeatureServer/0
I already added the 2nd one as a layer to Map Viewer Classic and it seems to be reading the events. But want to make sure this is the correct one to add.
Thank you.
JakeSkinner
Esri Esteemed Contributor
Hi @TimHayes3,
Either URL will work.  Each layer is added with an index value when published to a service.  If you have 3 layers in your service, by default, the index would be sequential for each layer (i.e. FeatureServer/0, FeatureServer/1, FeatureServer/2).
The first URL will add all layers within your service.  The second URL is calling an individual layer in the service by specify /0.  If your service only has one layer, then both are synonymous.
