SampleServer for GeoEvent Processor
5111
7
08-08-2013 04:42 AM
ChrisHarris
Do you know if there are any plans for ESRI to host a SampleServer (e.g. http://sampleserver6.arcgisonline.com/ArcGIS/rest/services) for 10.2 which includes a demo GeoEvents Processor dynamic service?
Chris
RyanElliott
There is not currently a publicly accessible demonstration server.  What kinds of actions were you wanting to try out?  If you just need a source of streaming data, we could probably find one.  If you need a server where you can create/modify streams of data then you would probably be better off with a server that you have exclusive access to so that other people aren't modifying streams at the same time as you are.
ChrisHarris
Thanks, at the moment primarily looking for map services containing dynamically-updating data to test Operations Dashboard against.
Chris
TimothyStiles
Hi Chris �??
I also wanted to point out that we've set up some publicly available raw sample feeds at:
http://ec2-54-224-125-57.compute-1.amazonaws.com/demosite/
These are meant to be used as sample feeds with:
---the new JavaScript Stream Layer (undocumented at the 3.5 release, documented at the 3.6 release)
---the GeoEvent Processor with an input that 'Receives JSON from an external Web Socket'
-Tim
Town_ofSnowflake
The link provided no longer works.  Is there an updated site with sample feeds?
TimothyStiles
The data feeds can be found at the following location: http://geoeventsample1.esri.com/demosite/
klem
Tim, how to define those streams in GeoEvent Processor? I've tried to use Subscribe to an external Web Socket for JSON connector with different combinations of url (using ws:// and http://) but incoming data count is "0". Of course I'm able to see the stream using any internet browser.
klem
RJSunderman
Hello Krzysztof,
Please take a look at the Forum thread GeoEvent Processor Web Socket Tutorial.
It appears that we have an issue leveraging the out-of-the-box connectors for the 10.2.0 product to consume feeds available from the http://geoeventsample1.esri.com/demosite. We are currently looking for a work around.
We apologize for the inconvenience. I'll post to both this thread and the thread referenced above if we can find a work around which doesn't require a patch to the product.
Best regards -
RJ
