Publishing Stream Service to Portal Issue
528
08-01-2024 08:36 AM
JacobBlankenship1
I have pulled in a stream layer that I created from GeoEvent into ArcGIS Pro using the server connection to GeoEvent server. After pulling in the dat I have update the symbology of the stream layer by a status attribute.
Now when I try and either publish a new web map or update a web map it wants me to registered it with the database or it will copy all the data to the database. No sure how to register a stream layer and I don't want it to copy the data over because I feel like that defeats the purpose of the stream layer.
I also changed the setting "Select a Configuration" to different ones just to see if it worked and it would try and create a new feature class but it still wouldn't work. ("Share As Web Map" Tool)
I was using this video as a guide - (skip to 41:55)
ArcGIS GeoEvent Server: Leveraging Stream Services (youtube.com)
Any help would be great,
