Publish Streaming Service Button Grayed Out in GeoEvent Server 11.0
1508
9
11-17-2022 08:07 AM
MichaelKastanotis
I am trying to publish a Streaming GeoEvent Service on a fresh deployment of GeoEvent Server 11.0
The Publish Streaming Service is grayed out. My understanding is that I need to use the Default server and the Root folder. I must be missing something in the site configuration?
MichaelKastanotis
Working with Esri support revealed that the GeoEvent Server machine needs to be authorized for both ArcGIS GeoEvent Server and ArcGIS GIS Server.
JohnLucotch2
Anybody figure this out?
MichaelKastanotis
JohnLucotch2
Great thanks so much!!
JosephSia2
Looks like the answer i'm seeking.
I thought it was already authorized because Geoevents is running.
Would you have any links I could refer to for authorizing both? Thank you.
Kiran_Rupali
were you able to resolve this issue? I am seeing the same problem in 11.1
GarrettMelvin
We recently upgraded from 10.9.1 to 11.1 and are experiencing the same issue.  We tried authorizing the server as GeoEvent Server, as well as authorizing as ArcGIS Server and GeoEvent Server, but that did not remedy the issue.  Our existing stream services published from 10.9.1. fail to start, we get the error message "Service failed to start" "This ArcMap based service cannot be started because the ArcMap Runtime Support feature is not installed."  Currently working with ESRI support to find a solution.
GarrettMelvin
It turns out in the upgrade our credentials were lost in the Default data store connection.  Supplying the credentials remedied the issue.
JohnLucotch2
Yes you need to authorize GeoEvent Server with both ArcGIS Server and GeoEvent Server.
Kiran_Rupali
thanks for the quick response. do you have steps on how to do that?
