Is there an option to change the drawing info of a Streaming Service from simple renderer to another renderer like unique value renderer on the service side?
3847
11-27-2015 05:59 AM
by Anonymous User
Not applicable
It would be nice to define the drawing info on the service side, so that all Clients are using the same drawing info.
RJSunderman
Hello Jan -
No, your options for changing the symbology for a stream layer in a web map to render the data being broadcast from a stream service are limited. You cannot use attributes to drive unique value rendering. Pretty much you are limited to a single symbol, although that symbol does not need to be a simple marker symbol, it can be an image (PNG, GIF, or JPEG).
- RJ
See Also:  How create symbology on stream layer
RJSunderman
Hello Jan -
- RJ
