How to create Geometry in the GeoEvent Service
3947
08-30-2017 11:05 AM
DanHuber
I have an input from a JSON service that does not always have values for the LAT, LON fields that is generating a lot of errors when trying to generate the Geometry field.    I've dropped the Create Geometry option for the input definition, and have created a filter that ignores records without LAT, LON values, but I'm unsure how to remap the Geometry field for my output definition.   I have a field mapping processor setup, but I'm not getting any data in my streaming service.
Dan
DanHuber
Hate leaving questions unanswered - even if they are my own.    I finally resolved my issue of creating the Geometry object after I received the JSON from the input.    There is actually a section in the Esri Introduction Tutorial that covers this - in Appendix A.
My solution involved doing the following in the GeoEvent Service:
  1. From the input, use a filter to reject all items that contained NULL longitude values
  2. Use the Field Calculator Processor to generate the Geometry object:
    • The Expression:  '{' + ' "x":' + lon + ',' + ' "y":' + lat + ',' + ' "spatialReference":{"wkid":4326} }'
Here is the GeoNet article that pointed me in the right direction.
Building Geometry from Fields
DanHuber
Gene_Sipes
Do you know if the function toPoint(long,lat,wkid) replaces this calculator expression? I am assuming the function wasn't available in 2017.
