GeoEvent Server 11.3 on Windows: GeoEvent Server 11.3: Persistent InstanceNotFound Errors referencing Services already deleted
534
02-25-2025 06:59 PM
KevinEscaleraRobles
I’m encountering a persistent issue with our ArcGIS GeoEvent Server 11.3 running on Windows Server. For a period, the system operated correctly, but at some point, something appears to have become corrupted. Now, on every restart, although the Windows services start, I cannot access the ArcGIS Server Manager unless I apply a hard reset to the GeoEvent instance. Even after the hard reset (which clears all inputs, services, etc.), the following error logs continue to be generated in the Karaf log constantly:
2025-02-26T15:19:56,478 | ERROR | qtp204224291-3195 | MonitoringRestServiceImpl | 20 - com.esri.ges.framework.i18n.i18n-support - 11.3.0 | com.esri.ges:name=e85c4bf8-377b-4f81-821a-555ad87b0d3a,type=geoeventservices
javax.management.InstanceNotFoundException: com.esri.ges:name=e85c4bf8-377b-4f81-821a-555ad87b0d3a,type=geoeventservices
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getMBean(Unknown Source) ~[?:?]
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getMBeanInfo(Unknown Source) ~[?:?]
at com.sun.jmx.mbeanserver.JmxMBeanServer.getMBeanInfo(Unknown Source) ~[?:?]
at org.jolokia.handler.ReadHandler$1.execute(ReadHandler.java:46) ~[?:?]
at org.jolokia.handler.ReadHandler$1.execute(ReadHandler.java:41) ~[?:?]
at org.jolokia.backend.executor.AbstractMBeanServerExecutor.call(AbstractMBeanServerExecutor.java:90) ~[?:?]
at org.jolokia.handler.ReadHandler.getMBeanInfo(ReadHandler.java:233) ~[?:?]
at org.jolokia.handler.ReadHandler.getAllAttributesNames(ReadHandler.java:245) ~[?:?]
at org.jolokia.handler.ReadHandler.resolveAttributes(ReadHandler.java:221) ~[?:?]
at org.jolokia.handler.ReadHandler.fetchAttributes(ReadHandler.java:183) ~[?:?]
at org.jolokia.handler.ReadHandler.doHandleRequest(ReadHandler.java:118) ~[?:?]
at org.jolokia.handler.ReadHandler.doHandleRequest(ReadHandler.java:37) ~[?:?]
at org.jolokia.handler.JsonRequestHandler.handleRequest(JsonRequestHandler.java:161) ~[?:?]
at org.jolokia.backend.MBeanServerHandler.dispatchRequest(MBeanServerHandler.java:156) ~[?:?]
at org.jolokia.backend.LocalRequestDispatcher.dispatchRequest(LocalRequestDispatcher.java:99) ~[?:?]
at org.jolokia.backend.BackendManager.callRequestDispatcher(BackendManager.java:429) ~[?:?]
at org.jolokia.backend.BackendManager.handleRequest(BackendManager.java:158) ~[?:?]
at com.esri.ges.rest.monitoring.internal.MonitoringRestServiceImpl.getInfoForObject(MonitoringRestServiceImpl.java:139) ~[?:?]
at com.esri.ges.rest.monitoring.internal.MonitoringRestServiceImpl.getMonitoringInfo(MonitoringRestServiceImpl.java:216) ~[?:?]
at Proxyba39aada_f3d5_4b4c_9a6f_86734c3cbbfc.getMonitoringInfo(Unknown Source) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor179.invoke(Unknown Source) ~[?:?]
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[!/:3.5.2]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[!/:3.5.2]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[!/:3.5.2]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[!/:3.5.2]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[!/:3.5.2]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[!/:3.5.2]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:307) ~[!/:3.5.2]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[!/:3.5.2]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[!/:3.5.2]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[!/:3.5.2]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[!/:3.5.2]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[!/:3.5.2]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[!/:3.5.2]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:304) ~[!/:3.5.2]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[!/:3.5.2]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[!/:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:279) ~[!/:3.5.2]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1626) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.websocket.server.WebSocketUpgradeFilter.doFilter(WebSocketUpgradeFilter.java:228) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548) ~[!/:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[!/:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[!/:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[!/:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[!/:9.4.43.v20210629]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[!/:?]
at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:763) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[!/:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [!/:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [!/:9.4.43.v20210629]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [!/:9.4.43.v20210629]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [!/:9.4.43.v20210629]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [!/:9.4.43.v20210629]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) [!/:9.4.43.v20210629]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) [!/:9.4.43.v20210629]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) [!/:9.4.43.v20210629]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [!/:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [!/:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [!/:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [!/:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [!/:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [!/:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [!/:9.4.43.v20210629]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [!/:9.4.43.v20210629]
at java.lang.Thread.run(Unknown Source) [?:?]
2025-02-26T15:19:56,480 | ERROR | qtp204224291-3195 | RuntimeExceptionMapper | 20 - com.esri.ges.framework.i18n.i18n-support - 11.3.0 | Created response for following exception.
java.lang.RuntimeException: javax.management.InstanceNotFoundException: com.esri.ges:name=e85c4bf8-377b-4f81-821a-555ad87b0d3a,type=geoeventservices
at com.esri.ges.rest.monitoring.internal.MonitoringRestServiceImpl.getMonitoringInfo(MonitoringRestServiceImpl.java:220) ~[?:?]
Caused by: javax.management.InstanceNotFoundException: com.esri.ges:name=e85c4bf8-377b-4f81-821a-555ad87b0d3a,type=geoeventservices
... 65 more
These errors occur for three services that I used to have configured. Despite having no inputs or services after a hard reset, the monitoring service still attempts to access stale MBean references for these former services.
I’ve followed the steps described in this post for 11.0 to try and resolve the issue. However, the error persists, and the server remains in a non-functional state until a hard reset is applied—which only temporarily alleviates if the server gets re-started, GeoEvent server will not start correctly.
Has anyone encountered a similar issue with GeoEvent Server 11.3 where stale MBean references persist even after a hard reset?
What additional steps can be taken to clean up these stale references or repair the corruption? Hopefully not re-install...
Any guidance or recommendations would be greatly appreciated.
Thank you in advance for your help!
