geoEvent input of a CSV file --
210
10-05-2025 01:30 PM
JeffSilberberg
Have a large CSV file with 26 Columns.  I can not get this file to import --
I defined the Input as Field1 - Field26 type String -
But Field 20 is a "ellipse.polygon.coordinates" and when I try to import it, geoEvent fails to parse this, and I sort of think it's because Field 20 is inside double Quotes, but I am not sure.
CSV Parse error. Error: vr3a6f68dda1283c12f47137907a6d1658,-114.1885,39.9274,1758412824,2025-09-21T00:00:24+00:00,1758412824629,2025-09-21T00:00:24.629+00:00,ic,6900,7,1758412824,2025-09-21T00:00:24+00:00,,,,,,,MultiPolygon,"[array([array([array([-114.18623352, 39.92692947]),.
The Full Field 19 contains "ellipse.polygon.type" value - MultiPolygon
While Field 20 contains "ellipse_polygon_coordinates" value -
array([-114.18623352, 39.92786407]),
array([-114.18684387, 39.92867279]),
array([-114.1878891 , 39.92913437]),
array([-114.18910217, 39.92913437]),
array([-114.1901474 , 39.92867279]),
array([-114.19075775, 39.92786407]),
array([-114.19075775, 39.92692947]),
array([-114.1901474 , 39.92612457]),
array([-114.18910217, 39.92565918]),
array([-114.1878891 , 39.92565918]),
array([-114.18684387, 39.92612457]),
array([-114.18623352, 39.92692947])], dtype=object)],
dtype=object) ]",
  I have tried changing Field 20 Cardinality to Multi, but that did not help.
  Hoping someone who has more experience than me might have an answer --
   TIA --
JeffSilberberg
A little more data from the log -- Type = Error
Com.esri.ges.adapter.text.TextInboundAdapter    CSV Parse error. Error: dtype=object) ]",105,200,200,656,656,reprocessedV1.
Com.esri.ges.adapter.text.TextInboundAdapter    CSV Parse error. Error: vr3a6f68dda1283c12f47137907a6d1658,-114.1885,39.9274,1758412824,2025-09-21T00:00:24+00:00,1758412824629,2025-09-21T00:00:24.629+00:00,ic,6900,7,1758412824,2025-09-21T00:00:24+00:00,,,,,,,MultiPolygon,"[array([array([array([-114.18623352, 39.92692947]),.
JeffSilberberg
Just thought I would bump this to see if anyone has any helpful pointers/tips.
