GeoEvent - GeoFence: FATAL Error
2507
02-26-2016 03:42 AM
Sardar_FaisalAbbas
I have 20GB RAM in my server and its a four core.
When I try to import a GeoFence (10000 points), the system gives me this error:
GeoFence FATAL ERROR: Your system has ran out of memory! We are attempting to free up space now. However the system might be in a non-recoverable state! Be prepared to restart your system if necessary!
Its only using 7GB of RAM and it gives me this error. Is there a way to fix it ? Can we increase the cap on RAM usage? Lastly, is there any other way using which I can match (perform point in polygon type of thing)  the assets on the ground with incoming points?
EdwardBuckley
When this happened to me, the "memory" referred to the HD, not RAM. Check the drive GeoEvent is installed on and see if it's almost full.
