Filter on Location for Incoming Tweets?
9210
12
08-04-2013 06:13 PM
by Anonymous User
Not applicable
Original User: jakc
I am using the latest Twitter connector for 10.2 and have it working fine when tracking keywords.
I would like to make use of the Locations field and enter a bounding box for a local region, but whenever I do, I get no incoming tweets.
I am using the bounding box for NY (as mentioned in the accompanying tutorial PDF), but when I then save this configuration, I get no incoming traffic (even after half hour) via the Monitor/TCP Console.  I have tried bumping the extent to a larger area, but still get no incoming traffic.
Have I done something wrong?
[ATTACH=CONFIG]26450[/ATTACH]
[ATTACH=CONFIG]26451[/ATTACH]
SimonJackson
Out of interest, did anyone get the locations parameter within the twitter input connector to successfuly work?
RJSunderman
SKCheruiyot
I believe I found the solution, I did the following to get tweets from a particular geofence only.
1. Import the polygon as a geofence on the SITE tab
2.Add the same polygon to the Geoevent Definitions
3.From the Geoevent Services tab add a filter.
That I believe solves the problem.
