Feature Service Outbound transport missing in 10.5.1
448
08-16-2017 12:52 PM
LakshmananVenkatesan
Hello
I could notice that my latest upgraded 10.5.1 GEP is missing Feature service outbound transport .
Has anything changed in 10.5.1 or this is missed during upgrade. I could find this in 10.4.1
Please advise
Feature Service Outbound Transportoutbound10.4.1Feature Service OutboundTransport implementation.
Tags (1)
AlexanderBrown5
Lakshmanan,
You should have it there:
Feature Service Outbound Transportoutbound10.5.1Feature Service OutboundTransport implementation.
The first thing I would do is contact technical support to see if they can help you import the missing transport.
If that is not an option they might advise to:
Backup your entire GeoEvent configuration using Configuration Store => Export Configuration => All
Uninstall GeoEvent and Delete leftover folders.
For example mine is installed here: C:\Program Files\ArcGIS\Server\GeoEvent
Reinstall and then import your configuration back into the interface.  Double check all your inputs,services, and outputs.
~Alex
