Can I edit a GeoEvent Definition outside of GEP Manager?
3195
01-02-2014 05:36 PM
DennisGeasan
I would like to edit the GeoEvent definitions outside of the GEP manager app. The GeoEvent definitions editor cannot handle group items. After editing a group item the group disappears and I have to reload the GeoEvent definition into the GE def editor. It would be easier to edit these not using the Geoevent Definition editor. Can I do this?
DG
RJSunderman
Hello Dennis -
Yes, you can edit a GeoEvent Definition by editing the XML you export from Manager, but this isn't exactly recommended. The 10.2.1 product release will include the ability to edit hierarchical (group) elements as well as cardinal (list) elements. The attached ZIP contains an MP4 video which shows this. The 10.2.1 product is scheduled for public release next week (January 7th).
If you do find yourself needing to edit and/or create an event definition outside of Manager, I've included a screenshot in the ZIP which shows how the XML nodes are nested for the 10.2.1 release. I don't think this has changed since 10.2 - but that is part of the reason for recommending that you not edit the XML yourself. If the development team decided to change the node structure we would consider that an internal change not necessarily advertise it. I wouldn't want you to borrow trouble by editing a file we didn't intend you to edit. Proceed with caution.
- RJ
