Where do the rangefans drop down values come from, and would you know why I am not seeing them? I don't have the Geoevent Server SDK installed. Is that required?
{ "name": "RangeFanProcessor", "label": "Range Fan Processor", "contact": "geoeventprocessor@esri.com", "description": "Returns range fan derived from event center, range, bearing, and traversal angle", "version": "10.2.0", "domain": "com.esri.geoevent.solutions.processor.geometry", "lastModified": "1393882661559", "propertyDefinitions": [ { "propertyName": "rangeSource", "label": "Range Source", "description": "Source of range Value", "propertyType": "String", "defaultValue": "", "mandatory": true, "readOnly": false, "displayOption": "", "dependsOn": "", "allowedValues": [ "Constant", "Event" ] }, { "propertyName": "range", "label": "Range", "description": "Maximum distance from event for analysis", "propertyType": "Double", "defaultValue": "1000.0", "mandatory": true, "readOnly": false, "displayOption": "", "dependsOn": "rangeSource=Constant" }, { "propertyName": "rangeEvent", "label": "Range Event Field", "description": "Geoevent field containing range data", "propertyType": "String", "defaultValue": "", "mandatory": true, "readOnly": false, "displayOption": "", "dependsOn": "rangeSource=Event", "allowedValues": [ "rangefans:event_id", "rangefans:x", "rangefans:y", "rangefans:z", "rangefans:geo", "rangefans:range", "rangefans:bearing", "rangefans:traversal", "rangefans:date", "rangefans:geodef", "buffer:eventid", "buffer:x", "buffer:y", "buffer:z", "buffer:radius", "buffer:date", "buffer:geodef", "TrackGap:trackId", "TrackGap:gap", "TrackGap:lastReceived", "TrackGap:geometry", "Flights-TcpText:FlightNumber", "Flights-TcpText:StartTime", "Flights-TcpText:OriginAirportCode", "Flights-TcpText:DestinationAirportCode", "Flights-TcpText:AircraftType", "Flights-TcpText:Altitude", "Flights-TcpText:Longitude", "Flights-TcpText:Latitude", "Flights-TcpText:geometry", "Flights:FlightNumber", "Flights:StartTime", "Flights:OriginAirportCode", "Flights:DestinationAirportCode", "Flights:AircraftType", "Flights:Altitude", "Flights:geometry", "ellipses:eventid", "ellipses:x", "ellipses:y", "ellipses:z", "ellipses:geo", "ellipses:major_axis", "ellipses:minor_axis", "ellipses:rotation", "ellipses:date", "ellipses:geodef" ] }, ...
Signed in members can post, follow updates, and more. New here? Register a free account.
