Ability to connect two instances of ACC to a single ArcGIS Enterprise 11.3 instance
426
03-05-2025 04:12 PM
Jamie_Till
We are on a project where GeoBIM is deployed to ArcGIS Enterprise 11.3. It is connected to ACC and working as expected. A second contractor is on the project and has a separate ACC instance, is it possible to have two ACC instances connected to a single ArcGIS Enterprise instance.
Looking at the JSON file required it doesn't look like it is possible to connect multiple instances. Any help greatly appreciated
ACheuvront
Hi @Jamie_Till,
You can connect as many ACC/BIM360 Hubs as needed to your ArcGIS GeoBIM instance but can only connect to a single Hub per GeoBIM project. The Hubs you would like to connect to need to have your APS client ID added as a custom integration.
You can add multiple ACC/BIM360 projects per GeoBIM project, as long as they are in the same Hub.
To add another Autodesk Hub please follow the Authorize the APS application for the Autodesk Construction Cloud account instructions for the Hubs you would like to connect to.
Aaron Cheuvront | Sr. Product Engineer - ArcGIS GeoBIM
Esri
