Unable to see "post update" button
1503
11-08-2011 07:49 AM
RuiMenezes
Hello everyone
I???m having some troubles with the Synchronizing Task and maybe you can help me.
I???ve made a simple mobile application following these steps:
??? Define two features classes in an Enterprise Geodatabase, setting them as versioned and adding Global ID
??? Define the mxd and the Map cache using the Mobile Tools (ArcToolBox)
??? I???ve made some changes and defined the tasks using ArcGIS Mobile Project Center
??? Finally, I deployed the project in the mobile
The problem is that when I try to post updates using the synchronizing task I can???t see the Post Upadates and the Get Data options (see the figure)
Probably, its quiet a simple solution.
Hope you can help me
Thank you very much
