Mobile 10.1.1 - Trouble Adding a Feature Service to Project Manager
1752
02-07-2013 04:39 PM
PeterTimmers
I'm looking at moving one of our mobile services to a feature service on our AGOL Organisation account and I've published the feature out there (with attachments).
Now I can' seem to connect to the account from the Project Manager (PM).
I may have initially used an old account but now with the new login all the PM does when I go load feature service it asks me for a login over and over again.
I know the login works with our AGOL Organisation.
Initially I'm think maybe it's our proxy firewall. But I'm able to use Mobile services from our external arcgis servers.
Any ideas?
GordonSumerling
Peter,
Looks like you go to the same stage I did when I started testing my mobile applications. There are two problems you are going to encounter.
1) You need to use https://<organization>/sharing (not http://). Make sure you, delete the old entry first from your options and exit Mobile Project Centre .
2)  On your AGOL feature service ensure you have the Enable Sync checked. This enables the ArcGIS Mobile editing. Full reference on all the settings can be found at Publishing a hosted Feature Service
All the best
Gordon
PeterTimmers
Not just an expert on image server Gordon? 🙂
That worked.
I was getting a little confused on the terminology.  I thought Portal was something you hosted yourself... not an arcgis.com subscription.
Peter
PeterTimmers
Aww damnit, stuck on another step.
You have to package the feature service in project center if you're going to use them, and it looks like this part of project center is not set up to use firewall proxy servers... even though everything else is.  See attached picture.
Should I report this one through ESRI Oz?
[ATTACH=CONFIG]21663[/ATTACH]
GordonSumerling
Peter,
I would recommend you now log this with support. Bit more complex now.
Cheers
Gordon
