We are using ArcGIS Mobile 10.0 installed on a Trimble Ranger handheld unit. The Ranger is running Windows Mobile 5.0 and .NET Compact Framework 3.5. We have created a test project using ArcGIS Mobile on a desktop and copied it to the Ranger, then opened the project and retrieved data. Everything is working as expected up to this point.
In the field ArcGIS Mobile will not get a GPS fix. I googled and found an article stating that ArcGIS Mobile requires the NMEA format and therefore a utility like Trimble GPS Controller must be used to output in NMEA format in order for a Trimble unit to communicate with ArcGIS Mobile. Timble GPS Controller has been installed on the Ranger and NMEA output is enables in the settings. The correct COM port is also set. ArcGIS Mobile still cannot get a fix.
Does anyone have experience with this issue?
