ArcGIS for Windows Mobile SSL
5428
01-15-2015 04:43 PM
MiklosNadas1
Has anyone configured ArcGIS for Windows Mobile SSL on an internal server? I currently have a pseudo reverse proxy set up to get around our internal and external firewalls. Whenever I try to connect through SSL on Mobile Project Center, it gives me the error in the attached screen shot. The text is:
The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
Any thoughts on why Mobile Project Center can't connect would be great. I'm assuming it's because I need two different certs and MPC is getting confused by what server it's connecting to.
DavidColey
MVP Frequent Contributor
Hi Miklos-
Why do you need two different certs?  The protocol for my internal cert uses both http and https, as does the COMODO cert on our web adaptor for external users....
David
MiklosNadas1
Thanks David!
I just needed to configure the cert to be signed. If iExplorer shows a warning saying it is an untrusted source, then Mobile Project Center would not work. I walked through this tutorial multiple times, but it finally worked (once I entered the right port)
Self-Signed Certificates on IIS 7 – the Easy Way and the Most Effective Way | Demystifying The Code
