Why the hotspot map can not show in IE with EM4C 5.0.1?
1090
11-07-2013 04:52 PM
lynnwang
When I run the report with hotspot layer in IE9, it bombs a box to me. It says that some IE settings don't support the hotspot map?
  Is it possible to show the hotspot map in IE9??
Tags (3)
PraveenChetty
Any one got this issue fixed. I cannot add heat map using IE. It works fine in Mozilla.
Thank you!!!
PraveenChetty
Thank you for the response.
We cannot ask users to use Mozilla or any other browser, do we have any other solution for the fix or we have to live with it.
Danielvan_den_Berg
I have similar issue with Internet Explorer 10 (Version 10.0.9200.16897).
I am using the ESRI Map plugin 5.01. as well with Cognos Version 10.2.1
Below the screenshot of the error:
Any inside or fix will be highly appreciated.
Daniel
