Sharepoint List with ESRI Maps Location Field is not discoverable in the ArcGIS WebPart
3280
06-05-2015 04:33 AM
JonHawkins
Hi
A list that displays in the ESRI WebPart is not discoverable in the ArcGIS WebPart even though the ESRI Maps Location field has been added.
When I browse to add the list, from the site, a message appears saying no graphical lists available.
Please Note:
  1. The ESRI Maps Location Field works as expected when editing items in the list. ie. points can be moved and updated
  2. The list is quite complex and has a number of options and workflows attached.
  3. I created test list in the same site with X,Y and ESRI Maps Location fields and this could be be discovered and added.
Has anyone had this issue or does anyone know of anything's that can stop a list from being displayed. eg. Length of field name, options, workflows etc....
JonHawkins
Managed to fix this problem. Discovered that the List View Lookup Threshold was set @ 80. When this was reduced to 8 [default] the list became discoverable
JonHawkins
